Hello Guest it is March 28, 2024, 09:42:20 AM
Author Topic: CNC is doing everything backward  (Read 1388 times)
« on: August 11, 2018, 02:31:40 PM »
Hi Everyone,
I ran into a problem with my first project. I made a sign but when it finished the sign is a mirror image. Instead of left to right it did right to left but the sign came out as if I am looking into a mirror. What do I need to do in Mach3 software to fix this
Vince
Re: CNC is doing everything backward
« Reply #1 on: August 11, 2018, 03:10:13 PM »
Hi.
you need to reverse the direction of the axes concerned.
Sounds like the X axis is backwards. Go to Config/Ports and Pins/Motor Outputs and check (or uncheck) <step active low> and hit <apply>
and try again.
Note this will reverse the homing direction if you have set it. Beware if you hit <Ref All>, the X axis may take off backwards.
« Reply #2 on: August 11, 2018, 05:08:09 PM »
That should be <direction active low> and hit <apply>. I don't think changing the step direction will do any harm but it won't
reverse the direction of the axis.
« Reply #3 on: August 11, 2018, 06:06:41 PM »
Thanks. Problem solved.
Vince
