Hello Guest it is March 28, 2024, 11:01:59 AM
Author Topic: Hilfe bei der Laser Einrichtung  (Read 9073 times)
  •  9,196 9,196
Re: Hilfe bei der Laser Einrichtung
« Reply #20 on: August 13, 2018, 10:50:29 AM »
Hi Matthias,
I am not sure this will help you because I am not using a Gcode file as such but these are my settings.
« Reply #21 on: August 13, 2018, 11:07:34 AM »
Thanks a lot.
When i am back home i will try that and see what happens...
Mathias
« Reply #22 on: August 14, 2018, 05:23:50 PM »
i think really the Laser is the Problem.
Even if i takte a very low laser intensity, the color is burned, but
the letters looking black and not white, because the sprayed color is burned.
Hope you understand what i mean?
I dont know if it is possible to solve that without another laser.
I think it is the difference in the nm of the laser, my is at 450nm, but a Co2 is at a higher nm, i think over 1000nm.
Matthias
  •  9,196 9,196
« Reply #23 on: August 15, 2018, 01:36:22 AM »
I think you may be correct but I have never used a blue laser so I do not know for sure.
Each laser type (wavelength) certainly has it's own advantages and disadvantages.
