Hello
Guest
it is
March 28, 2024, 05:47:45 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 DRO & toolpath NOT refreshing
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 DRO & toolpath NOT refreshing (Read 2433 times)
George GR
1
on:
August 07, 2018, 06:26:45 AM »
Hi!
Few days now I have a little problem.
When I move to any axis the DROs and the toolpath screen not renewed. When I stop the movement then the DROs and toolpath screen jumps to the correct position. Even when I run a program (toolpath) they still frozen antil the job finish or I press RESET or Feed Hold. Then they jump again to the correct position. For some reson the g-code screen working right. It dosen't mater if I make the movemed via keyboard or pentant.
Any help!!!
Logged
Ingevetl
2
Re: Mach3 DRO & toolpath NOT refreshing
Reply #1 on:
October 10, 2019, 02:01:47 PM »
Hawe the same problem hawe to power off everything to empty ees, than its working.
Logged
deejay_56
1
Reply #2 on:
May 06, 2021, 02:29:16 PM »
Hi. I'm having the same problem, and using Pokeys57cnc board. Have you resolved the problem and if so, how?
Logged
Ingevetl
2
Reply #3 on:
May 07, 2021, 10:35:00 AM »
I'm having still the same problem, and using Pokeys57cnc board and wix hc whb04b-6 MPG Handwheel
Logged
Anono-mouse
1
Reply #4 on:
July 07, 2022, 07:45:36 AM »
Updating PoKeys (Firmware and Software) to the latest version (v4.6.1) fixed this for me
Credit goes to PoLabs support for the solution
Logged
stevenladner
1
Reply #5 on:
February 16, 2023, 04:35:23 AM »
Even though I have updated to the new version, I still get the same error. Should it be resolved?
geometry dash meltdown
Logged
tesemebe
2
Reply #6 on:
April 19, 2023, 12:50:30 AM »
I'm still having the same issue, and I'm making use of a Pokeys57cnc board in conjunction with a wix hc whb04b-6 MPG Handwheel.
backrooms game
Logged
Print
Pages:
1
Go Up
« previous
next »
