Hello
Guest
it is
April 26, 2024, 02:42:40 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Mach4 engraving CNC laser machine missing steps and regaining them ...?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Mach4 engraving CNC laser machine missing steps and regaining them ...? (Read 3540 times)
Tweakie.CNC
9,200
Super Kitty
Re: Mach4 engraving CNC laser machine missing steps and regaining them ...?
Reply #10 on:
July 22, 2018, 06:42:58 AM »
Your Gcode looks fine, which motion controller are you using ?
Logged
bartvano
14
Reply #11 on:
July 22, 2018, 07:26:27 AM »
i'm using the pokeys 57 CNC
But the i also trie this in MDI
G00 X20
M62 P1
G00 X0
M63 P1
and the output stays high all the way tru....?
Logged
Tweakie.CNC
9,200
Super Kitty
Reply #12 on:
July 22, 2018, 08:14:24 AM »
I do use a 57CNC for laser work but not with Mach4 so I do not know if the 57CNC actually supports the M62/M63 commands. May I suggest that you contact PoLabs to check this before proceeding;
http://support.polabs.com/
Last Edit: July 22, 2018, 08:16:21 AM by Tweakie.CNC
Logged
bartvano
14
Reply #13 on:
July 22, 2018, 08:22:36 AM »
i will check it, but i don't think the gcode M62-63 has ennything to do with the pokeys 57cnc it is in mach 4 ....?
mach 4 reads the M62-63 an just puts this to an output of the pokeys....
Logged
Tweakie.CNC
9,200
Super Kitty
Reply #14 on:
July 22, 2018, 11:07:30 AM »
So it would seem but...
Because the M62/M63 commands only take effect at the instant of axis movement then the Output# would have to be controlled by the 57CNC plugin.
Logged
bartvano
14
Reply #15 on:
July 24, 2018, 02:33:55 AM »
I got this from polabs
We are in contact with Mach4 team on how to solve this issue and implement real-time outputs control.
So you were right
Logged
Tweakie.CNC
9,200
Super Kitty
Reply #16 on:
July 24, 2018, 03:12:50 AM »
My apologies for suggesting the M62/M63 route - looks like you are back to using an axis direction pin for the time being.
However, I think PoLabs will be pretty quick to implement these commands into their plugin.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
