Hello Guest it is April 25, 2024, 01:23:03 PM
Author Topic: Using a macro to "ref all home"  (Read 13078 times)
Re: Using a macro to "ref all home"
« Reply #20 on: August 16, 2018, 10:27:58 AM »
I see.
Offline TPS
  •  2,505 2,505
« Reply #21 on: August 16, 2018, 03:09:07 PM »
witch motioncontroler areyou using?
« Reply #22 on: August 16, 2018, 05:50:10 PM »
Mach3 XHC MK4-IV
Offline TPS
  •  2,505 2,505
« Reply #23 on: August 17, 2018, 01:42:43 AM »
ok, but anyhow it is courios, that you can run the M12 via MDI without any Problem,
and by enabling the Ignore M calls while loading it should not go into the macro.
i have two further ideas to test (without any idea of the real reason):
- rename the M12 to M312 for example
- put additional code into M12
If Not() IsLoading() Then
   ..your M12 code here
End If
Thomas
« Reply #24 on: August 21, 2018, 07:03:09 PM »
I copied M12 and renamed to M312... same results
I modified the M312/M12 file, it now reads as:
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
DoOEMButton(133)
DoOEMButton(134)
DoOEMButton(135)
End If
When I type M312 into MDI, I get this error - Scripter Compile Error. In:M312.m1s
« Reply #25 on: August 21, 2018, 07:36:17 PM »
I don't know VB but:
Not() IsLoading()
Doesn't look right to me.
Try:
 Not(IsLoading())
« Reply #26 on: August 21, 2018, 07:40:40 PM »
Try :
If Not IsLoading() Then
« Reply #27 on: August 21, 2018, 07:48:55 PM »
I rewrote the Macro with both Not(IsLoading()) and Not IsLoading(), Not IsLoading() returned the same error and Not(IsLoading()) ran the macro in MDI OK and caused the same loop when running as a part of my header
« Reply #28 on: August 21, 2018, 08:04:05 PM »
Gerry is way more experienced in VB than I, if he suggests:
Not IsLoading() that is the correct syntax.
« Reply #29 on: August 21, 2018, 08:26:02 PM »
The code runs fine like this in MDI
If Not(IsLoading()) Then
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
DoOEMButton(133)
DoOEMButton(134)
DoOEMButton(135)
End If
Code returns the error   Scripter Compile Error. In:M312.m1s     when written like this:
If NotIsLoading() Then
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
DoOEMButton(133)
DoOEMButton(134)
DoOEMButton(135)
End If
