Hello Guest it is April 25, 2024, 08:16:51 PM
Author Topic: Using a macro to "ref all home"  (Read 13090 times)
Re: Using a macro to "ref all home"
« Reply #10 on: July 16, 2018, 02:07:16 PM »
Interesting, OK.     DO you know where I can download version .042?
If the problem is in fact the card, what is a reputable 4+ axis controller card?   (using 2 axii now but about to add 2 more) hence why I need 4+
« Reply #11 on: July 16, 2018, 02:36:17 PM »
The current version on the website is 3.043.062.
Any controller not made in China should work, but I'd ask if it supports G28.1 before purchasing.
Offline Graham Waterworth
  •  2,673 2,673
  • Yorkshire Dales, England
« Reply #12 on: July 20, 2018, 08:31:42 PM »
What happens if you just run this bit of code no extra bits or edits.
G21 G40 G49 G80
G91 G28.1 Y0 Z0
M30
« Reply #13 on: July 24, 2018, 11:38:10 AM »
Graham - same thing.   This machine gets caught in a loop touching off the Y and Z switches
« Reply #14 on: August 14, 2018, 03:06:18 PM »
I downloaded the version of Mach3 from Artsoft's website (v3.043.062) rolling back from the version which came with the machine (v3.043.066) and things still behave the same.
All the code act the same in both versions -ie repeating forever when ran as a gcode file and working as predicted when typed into MDI.
Do you still think this could be the control card?  Is there anything else I can try before trying a different card?
Offline TPS
  •  2,505 2,505
« Reply #15 on: August 15, 2018, 04:44:44 AM »
have you tryed to run your M12 Version with
Config -> General Config -> Ignore M calls while loading    enabled?
« Reply #16 on: August 15, 2018, 11:36:06 AM »
I just tried "Config -> General Config -> Ignore M calls while loading    enabled?"  and restarted my software and tried again.   Still get the same results, the machine gets to M12 and rewinds to the top of program.. over and over again.
G21
G90
G53         Z   0
G0 G54   Y   -79
M12
G0   Y   -79
T1 M6                     S   3250   M3
G43 H1         Z   15
G1                F   250
Offline TPS
  •  2,505 2,505
« Reply #17 on: August 15, 2018, 01:18:24 PM »
ok tested this here
code M12 macro
Code: [Select]
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
DoOEMButton(133)
DoOEMButton(134)
DoOEMButton(135)
gcode file:
Code: [Select]
G21
G90
G53 Z0
G0 G54 Y-79
M12
G0 Y-79
T1 M6 S3250 M3
G43 H1 Z15
G1 F250
without any Problem, maybe somebody else can do the test as well, to doublecheck.
« Reply #18 on: August 15, 2018, 01:27:28 PM »
Thanks for checking!!          What control card you using?
Offline TPS
  •  2,505 2,505
« Reply #19 on: August 16, 2018, 02:32:04 AM »
i tested on my testsystem witch is PP, no motioncontroler.
