Hello Guest it is April 25, 2024, 03:08:20 PM
Author Topic: Mach4 Mid Job Shutdown / Restart  (Read 1803 times)
« on: June 19, 2018, 09:21:13 AM »
Hello,
I'm using Mach4 on a 3 axis CNC router; machining long run (8+ hour) jobs.
I'm sure it's already been discussed elsewhere here before... if I wanted to completely power down Mach4 and the machine, and restart from where I left off, what's the best way to go about it?  For example, if a storm comes up I would like to shut down to avoid an outage, or can only machine 3 hours into an 8 hour job and want to restart where I left off.
Is it possible to do a FEED HOLD / Power everything off / Power everything on / CYCLE START ?
Thank you for your help!
Re: Mach4 Mid Job Shutdown / Restart
« Reply #1 on: June 19, 2018, 10:06:53 AM »
No.
You will need to remember where you left off and then do a run from here when you start up again.
Mike
« Reply #2 on: June 19, 2018, 10:08:09 AM »
I have had good luck with "Run from here", other people say it is temperamental.
There was a post on here that had a little bit of a discussion about it but I'm not having any luck finding it right now.
Actually, thinking about it, Bryanna could make a video on "Run from here" to show people how to use it properly.  Just a thought.
« Last Edit: June 19, 2018, 10:11:50 AM by Cbyrdtopper »
Chad Byrd
« Reply #3 on: June 19, 2018, 05:09:54 PM »
I have used run from here and it is much better in Mach4 than it was in Mach3.
+1 on the video idea.
Mike
« Reply #4 on: June 19, 2018, 06:25:20 PM »
Thank you for the feedback Mike & Cbyrdtopper!
