Hello Guest it is April 24, 2024, 01:57:42 AM
Author Topic: ISEL 3020 Conversion  (Read 2013 times)
Offline Myk3
  •  15 15
« on: June 18, 2018, 01:47:20 PM »
I am fairly new to the build your own controller field.. I am converting a ISEL 3020 to Mach3 and I have the X and Y running but am unsure on how to calculate the microstepping and the section for motor tuning (Steps per, velocity, Acceleration, and Pulse). Is there a formula to use to calculate these?
The ISEL 3020 has  these motors installed.
I installed these drivers and this BoB.
video of the thing moving
Thanks for any advice..
Offline Myk3
  •  15 15
Re: ISEL 3020 Conversion
« Reply #1 on: June 18, 2018, 03:02:56 PM »
Further research I found these on the documentation..
  •  9,199 9,199
« Reply #2 on: June 19, 2018, 01:49:33 AM »
With microstepping it is usual to select 1/8 if your machine parts and workings are going to be in Imperial units and 1/10 if it is going to be in Metric units.
Here is a calculator which will help you calculate the Steps per Unit for each axis; http://www.machsupport.com/forum/index.php?action=dlattach;topic=16315.0;attach=23771
Velocity and acceleration are a ‘trial and error’ thing…
Increase Velocity in steps until an axis regularly stalls (squealing noise) then reduce it by 30% saving the changes as you go. Acceleration is set in a similar manner. Then they are both finely adjusted for optimum performance.
« Last Edit: June 19, 2018, 01:55:36 AM by Tweakie.CNC »
Offline Myk3
  •  15 15
« Reply #3 on: June 19, 2018, 09:59:27 AM »
Ahh! thanks a bunch!
