Hello Guest it is April 25, 2024, 07:32:50 PM
Author Topic: Ess Reset Velocity N. Disabling mach  (Read 4295 times)
« on: June 18, 2018, 12:57:46 PM »
I built this cnc router and tried to fire it up to drill a series of holes to screw the spoil board to the table. I am using mach4 (the trial version) ESS, the new version and V Carve Pro. A couple of question here: I did a little drawing to lay out the holes, tool path etc. and saved the tool path, when a tool path is saved what file ext. does it save as? Mine saved as a txt. I used that. When I ran that I got a message, "ESS Reset Velocity N. Disabling Mach". What does that mean?
  •  9,199 9,199
Re: Ess Reset Velocity N. Disabling mach
« Reply #1 on: June 19, 2018, 02:07:03 AM »
Hi Mr.Toad,
To avoid duplication this topic is already being dealt with by Andy (the expert) on the Warp9 forum;  https://www.warp9td.com/index.php/kunena/7-general-discussion/7576-woodworker-needs-help?start=36
