Hello Guest it is April 26, 2024, 10:14:00 PM
Author Topic: Cutting an internal thread  (Read 1162 times)
« on: June 13, 2018, 04:26:30 PM »
Well I've reached the stage where I need to cut an internal thread on the CNC lathe.  I use the Simple Threading wizard for OD threads but there's no obvious way to tell it I want an internal one.  On the other hand if I make X End larger than X Start in the wizard it generates code and doesn't raise an error - is that the way to use it for ID threads please?
Re: Cutting an internal thread
« Reply #1 on: June 14, 2018, 04:19:36 AM »
Answering (I think) my own question, running in simulation mode suggests that this does indeed work.
