Hello Guest it is April 26, 2024, 04:47:54 PM
Author Topic: Mill Wizard Feed Rate  (Read 6275 times)
« on: June 08, 2018, 10:28:25 PM »
I have a question about the feed rate that the wizard puts out. Everything looks good except it inserts a feed rate equal to the plunge rate just before the main G code. I have attached an example of the code. It is easy to fix just by editing it out but I wonder why it puts it there. Thank you for any insight on this.
Re: Mill Wizard Feed Rate
« Reply #1 on: June 08, 2018, 10:51:10 PM »
I am not sure what you see. the comments show you have a feed rate of 322.5500 and a plunge rate of just 0.5. That sounds really strange, did you enter those values in the tool screen? I dont think the program would have calculated such values.
I dont see the code using that plunge rate anywhere.  Please give me the line number where you see  that.
Code: [Select]
(posted for Aluminum )
(Strategy: Equal )
(Rapid height: 1.0000  Clearance height: 0.0500 )
G98 G80 G17 G90 G54 G64 G91.1
G21 G90
(***New Tool Selected***)
(ToolNum: 01  Diameter: 3.0000  )
(Feed: 322.5500  SFM: 152.0000  Plunge: 0.5000  ChipLoad: 0.0100  )
M06 T1 ()
G43 H1
M03 S16128
(***Cut Rectangle***)
(Groove)
(Xorign: 5.0000  Yorign: 0.0000  Length 2.0000  Width: 2.0000  CorR: 0.0000  InOut: 02  )
(Ztop: 0.0000  Zdepth: -0.5000  Zstep: 0.5000 )
(will make  1.0000  cuts of:  0.5000 )
(Rotated around X,Y orign by 30.0000 degrees)
G00 Z1.0000
X4.0000 Y1.7321
Z0.0500
G01 Z0.0000 F322.55
F0.50
Z-0.5000
X5.7321 Y2.7321
X6.7321 Y1.0000
X5.0000 Y0.0000
X4.0000 Y1.7321
G00 Z1.0000
M09
M05
M30 (end of file)
« Reply #2 on: June 08, 2018, 11:07:28 PM »
If you look just after the Line "G01 Z0.0000 F322.5" the wizard inserts F0.50 just before the main run to make the cut.
« Reply #3 on: June 09, 2018, 07:24:49 AM »
OK, sorry, I missed that line. Should stop reading forums after bedtime.
the "G01 Z0.0000 F322.55 " is doing a rapid drop to the surface of the work- its still above the work, in the air, so I move rapid to save time.
Then the F 0.5 is  issued because we are at the surface and starting to plunge into the work.
The next move is the plunge to the first cut so we must use the plunge rate.
The error in the code is that we should then issue a feedrate  because we start to make X,Y moves. In fact because of the model nature of G01, all the following G01 moves will be to slow.
You want to edit the code to add an F322.5 to the line "X5.7321 Y2.7321 "
I thought this got fixed some time ago, but to be honest I have not made an update in some time. Are you running the latest version?
« Reply #4 on: June 09, 2018, 11:02:03 AM »
Hi Ron
This has been a sore for ages and was not fixed in the latest version. It would be great if you could fix it soon, thanks
Allan
« Reply #5 on: June 09, 2018, 01:49:44 PM »
Thanks for the replies. I was wondering if I was just missing something in the set up. Not a big deal to correct now that I know.
« Reply #6 on: June 09, 2018, 01:55:29 PM »
Ron I'm running 2.0.4X according to the about in help. I did download the latest version from Newfangled. It indicates version 2.0.5 in the download file name. I did uninstall the previous version first but it still came up in about saying " 2.0.4X"
« Reply #7 on: June 09, 2018, 02:12:11 PM »
I believe 2.04X is the latest. I will talk to Brian about fixing this.
