Hello Guest it is April 24, 2024, 08:21:27 PM
Author Topic: Stepper calculations  (Read 1330 times)
« on: June 06, 2018, 11:09:28 PM »
Hi, I'm kinda a newbie to Mach software and a little confused about the stepper calculations. I came across this calculator which was very helpful: http://www.machsupport.com/forum/index.php/topic,16315.0.html. I was wondering how the feed values translate to pulse/sec and motor RPM. Whats the formula for that?
Re: Stepper calculations
« Reply #1 on: June 13, 2018, 09:35:04 PM »
{most} Stepper motors take 200 full steps/rev. if you have a pulley or gear with a pitch diameter of 1" you will get 1" of travel per 200 steps. and so on. speed is relative to your machine, size of stepper etc. etc. so there is not a newby answer for this one. Yes everything can be calculated. If you are embarking on a cnc build I would suggest copying some ones design that has a proven machine. buying the wrong parts and then buying the right parts cost a lot of money and time.
Weldsmith
