Hello
Guest
it is
April 27, 2024, 12:47:01 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
HiCON Motion Controller
(Moderator:
Vital System Support
Mach 4 tracking limit error
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 4 tracking limit error (Read 3760 times)
stoneman1
3
on:
June 04, 2018, 09:28:41 PM »
Ok I am new to mach 4 and the Hicon integra board. I am using clear path servos and can only get them to make a small move before getting error of tracking limit exceeded on all axis. I am not sure where to start to fix this problem and was hoping someone out there has had this problem as well and could point me in the right direction. I have the tracking error limit set to 6400 in the clear path software and even tried to turn it off just to see if i could get movement more then a pulse or two. Your help is much apperciated!!
394
Re: Mach 4 tracking limit error
Reply #1 on:
June 05, 2018, 11:00:44 AM »
Is the error showing in the VSI debug window or Mach4 history log?
stoneman1
3
Reply #2 on:
June 08, 2018, 08:28:17 AM »
I have figured out this problem thanks for the response. but I have another question. The spindle set up on the DCM or RLC relay in order for the spindle to turn on when I hit the switch it should be reading 24v correct? I can hear the relay kicking on and off but Im not getting any voltage from it.
394
Reply #3 on:
June 08, 2018, 11:34:02 AM »
If you have the relay common wired to +24V then the relay output will source +24V. Normally, the relay common is wired to the DAC which will output 0-10V depending on the speed settings of the spindle in Mach4.
Print
Pages:
1
Go Up
« previous
next »
