Hello
Guest
it is
April 25, 2024, 08:12:08 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
HiCON Motion Controller
(Moderator:
Vital System Support
Mach 4 tracking limit error
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 4 tracking limit error (Read 3606 times)
stoneman1
3
on:
June 04, 2018, 09:28:41 PM »
Ok I am new to mach 4 and the Hicon integra board. I am using clear path servos and can only get them to make a small move before getting error of tracking limit exceeded on all axis. I am not sure where to start to fix this problem and was hoping someone out there has had this problem as well and could point me in the right direction. I have the tracking error limit set to 6400 in the clear path software and even tried to turn it off just to see if i could get movement more then a pulse or two. Your help is much apperciated!!
Logged
394
Re: Mach 4 tracking limit error
Reply #1 on:
June 05, 2018, 11:00:44 AM »
Is the error showing in the VSI debug window or Mach4 history log?
Logged
stoneman1
3
Reply #2 on:
June 08, 2018, 08:28:17 AM »
I have figured out this problem thanks for the response. but I have another question. The spindle set up on the DCM or RLC relay in order for the spindle to turn on when I hit the switch it should be reading 24v correct? I can hear the relay kicking on and off but Im not getting any voltage from it.
Logged
394
Reply #3 on:
June 08, 2018, 11:34:02 AM »
If you have the relay common wired to +24V then the relay output will source +24V. Normally, the relay common is wired to the DAC which will output 0-10V depending on the speed settings of the spindle in Mach4.
Logged
Print
Pages:
1
Go Up
« previous
next »
