Hello
I modified a milling machine BF30 Optimum by adding a motorization on the 3 axes as well as for the turntable. I use a Pokeys57cnc and 4 drivers PoStep60_256.
I have been running Mach4 for a while and everything works with GCode programs.
Since I do a lot of development in VB.net (I master the programming), I started to modify the screen of Mach4 to add personal features.
I read "Mach4 Screen Editor V1.0" and "Mach4 LUA Scripting Manual". I saw that in the help of the script editor, there is the list and definition of Mach core API functions (mc.).
When I look at some examples of scripts, I see that there are wx functions. (ex: wx.wxPanel, wx.wxMessageBox, ...), functions str (ex: scr.SetProperty, scr.ExecMdi, ...). And maybe others!
Where can I find the list of all these functions (wx, str, ...) with the syntax and parameters to use?
Thank you all for your help.
Jean-Pierre
