Hello
Guest
it is
April 25, 2024, 02:41:03 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
large g-code problem on mach3
Poll
stuck my axis when load larg g-code 900.000 lines
g-code problem
0 (0%)
mach3 stuck
0 (0%)
Total Members Voted:
0
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: large g-code problem on mach3 (Read 4344 times)
stefanos
2
on:
May 31, 2018, 07:02:28 AM »
hello .I have problem with mach3 when load large g-code 900.000 lines. Mach3 is begin slow and when i move axis loosing a lot of steps and stuck, in other smaller g-code files runs without problem , i use a full version on mach3 and i have pc windows7 with intel pentium4 3ghz , memory 3ghz and graphic card amd radeon r7 1ghz memory. How to solve the problem? (sorry for bad english)
Tweakie.CNC
9,199
Super Kitty
Re: large g-code problem on mach3
Reply #1 on:
May 31, 2018, 08:12:55 AM »
As a test try turning off the Toolpath Display (Diagnostics screen) - if your 900,000 line code then runs OK the problem is most likely with your graphics card.
stefanos
2
Reply #2 on:
June 05, 2018, 01:09:31 PM »
thank you very much , the problem is from toolpath, now works fine.
Tweakie.CNC
9,199
Super Kitty
Reply #3 on:
June 06, 2018, 02:15:16 AM »
I am pleased you found the problem.
(Perhaps consider fitting a new Graphics card with 1GB or more memory).
ger21
6,295
Reply #4 on:
June 06, 2018, 11:01:10 AM »
He already has one, according to his first post.
Print
Pages:
1
Go Up
« previous
next »
