Hello Guest it is April 25, 2024, 09:25:22 PM
Author Topic: Mach 3 Galil to Mach 4 Galil  (Read 5227 times)
« on: May 25, 2018, 10:30:47 AM »
Hi I have a DMC 4080 that I have been using for a while with Mach 3 and the Galil Plugin with steppers.
I am now trying to migrate to Mach 4 and the new Galil plugin with the same steppers and limit set up on x, y and z (using same plugs and wiring into the 4080)
However, I cant seem to get the motors moving at all with Mach 4 /Galil Plugin (both are licensed and using xp)
I keep getting Galil 20 Begin not valid with motor off error come up both with and without mapping the limit switches.
Any assistance would be appreciated.
Barry
Re: Mach 3 Galil to Mach 4 Galil
« Reply #1 on: May 28, 2018, 01:53:09 PM »
Sorted now using the galil wsdk  was a problem with the limit switch setup
Barry
