Hello Guest it is April 26, 2024, 05:53:08 PM
Author Topic: G-code help  (Read 3299 times)
G-code help
« on: May 16, 2018, 08:24:41 PM »
I’m retired navy and my son is active duty and I want to make his new Command ship crest. I’m having a difficult time with Creating the G-Code on my computer, it just keeps freezing. What would the best way to tackle this?
  •  9,200 9,200
Re: G-code help
« Reply #1 on: May 17, 2018, 03:15:01 AM »
Hi Marcmora,
Welcome to the forum.
Firstly you need a high resolution image of the crest then it can be traced (various software available to do this - Inkscape is free) to produce one or more .dxf's (vector files). A Gcode file can then be produced from the vector file (again various software available to do this - LazyCam is free but there are better products available).
If you use a CAD/CAM software (such as Vectric Aspire) you could create a V-Carve type of crest (also check out F-Engrave - this is free).
Overall there is a lot of work (and learning) involved in creating the required Gcode but learning can be fun  ;)
Re: G-code help
« Reply #2 on: May 17, 2018, 03:15:06 PM »
I use Inkscape and i have the SVG. I will try lazy cam. thank you for the input.
Re: G-code help
« Reply #3 on: May 18, 2018, 02:28:46 AM »
F-Engrave, free, can do text or relief image engraving from a png.
« Last Edit: May 18, 2018, 02:30:41 AM by JohnHaine »
