Hello Guest it is March 28, 2024, 10:31:08 PM
Author Topic: Galil and Mach 4 Plugin - Probe Connection  (Read 2613 times)
« on: May 14, 2018, 07:24:37 AM »
Hi I have decided to update my BP series 1 CNC to mach4 using the galil plugin to a DMC4080 via steppers. Using the following setup works fine.
My current motor connections are A, B and C using External Driver Connections (A to D) STPA DIRA; STPB  DIRB; STPC, DIRC   i.e. Pins: 16, 19, 31, 34, 2, 5
With limit switches and home switches using I/O (A-D) Connections FLSA,  FLSB, FLSC; RLSA RLSB, RLSC; HOMA HOMB HOMC.   i.e. Pins: 36, 37, 38, 22, 23, 24, 7, 8,9
I am now looking to install an external probe onto the machines x Axis.  After reading the install PDF I am a little confused as to how to wire the probe up to the "Galil high speed position latch functions".
Am I correct in thinking that the Galil high speed position latch functions pins are pins 1, 2, 3 on the I/O (A-D) Connector?
Or do they refer to DI1, DI2, DI3 on the I/O (A-D) Connector?
I think the latter is correct any assistance greatly appreciated.
Barry
