Hello Guest it is April 18, 2024, 01:33:43 PM
Author Topic: A way to control the direction on VFD  (Read 3260 times)
« on: May 12, 2018, 06:41:04 PM »
I have a -10V to +10V signal from a device which I would like to control a AC Tech VFD with https://www.clrwtr.com/Products/ESV751N04TXC.
I want at -10V the motor to reverse & at +10V the motor to go forward. At 0V the motor should stop.
Can this be done?
Re: A way to control the direction on VFD
« Reply #1 on: May 12, 2018, 07:37:43 PM »
Looking at page 35 P159 mentions +-10v, but P158 above says it is not currently supported. No wiring diagrams show it either so I believe you are out of luck.
« Reply #2 on: May 12, 2018, 08:51:05 PM »
Hi Luke,
just as a matter of interest why do you want it to go backwards? Do you have LH cutting tools or LH drills?
« Reply #3 on: May 13, 2018, 11:06:34 AM »
Tapping?
« Reply #4 on: May 14, 2018, 12:35:58 AM »
yes tapping, but VFD driven spindles have such poor torque at low speed that it doubtful it will work
unless its a really big spindle. Additionally you'll need some sort of encoder to synchronise with the
other axes, and position control with asynchronous spindles is fraught at best.
Offline reuelt
  •  520 520
« Reply #5 on: April 20, 2019, 11:35:13 AM »
Can this be done?
YES it can be done PROVIDED your BOB (Break out Board) has two relays.
One relay controlled by M3 say output 1 (pin ##)  is connected to connector 13A of the Inverter.
2nd relay controlled by M4 say output 2 (pin ##)  is connected to connector 13B of the Inverter.
Digital Ground connected to 1 & 4 as in attached diagram.
On the inverter
Set P112 to 1
Set P121 to 13
Set P122 to 14
ANI connection REMAINS same.
"the gift of God is eternal life through Jesus Christ our Lord"
