Hello
Guest
it is
April 25, 2024, 11:16:03 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Support
Forum suggestions and report forum problems.
Need Help
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Need Help (Read 7417 times)
manoj2s
10
Need Help
on:
July 19, 2007, 07:43:42 AM »
Hi
I am new to Mach software but we have developed our Stepper Drive weith (Enable + Step + Direction) Input.
Can anybody guide us how to Configure this software MACH 3 for our application
Regards, Manoj
Logged
lpz
6
Re: Need Help
Reply #1 on:
November 01, 2007, 10:02:24 PM »
I can't get mach3 to run in MM units, even using G21 at the begining of my coding. How do I get the s/w to run in MM only, running XP.
Logged
Graham Waterworth
2,673
Yorkshire Dales, England
Re: Need Help
Reply #2 on:
November 02, 2007, 10:28:48 AM »
go to config, set native units.
Graham.
Logged
lpz
6
Re: Need Help
Reply #3 on:
November 03, 2007, 09:09:11 PM »
The problem I am having is getting the controller to work in MM. I use G21 at the start of code but the part is produced in inches. When I tuned up the motors I was able to do this in MM. The units button on the diag page is set to MM.
Thanks for any help
LZ
Logged
Graham Waterworth
2,673
Re: Need Help
Reply #4 on:
November 04, 2007, 09:46:32 AM »
Have you set the steps per correctly in the motor tuning window?
What is creating the code for you?
if you run this code with a pencil in the chuck what size is the 25mm square it should be making
g21 g40 g00 g90
x0 y0 z25.
z0
g01 x25 f100.
y25.
x0
y0
g00 z25.
m30
Graham.
Logged
lpz
6
Re: Need Help
Reply #5 on:
November 07, 2007, 09:24:23 PM »
thanks using your code I was able to get my system to switch units.
My new problem is with the A axis. What settings do I need to set to enable my A axis to work in degrees. Right now when the A code sees 1 it makes 1 rev, I need it to move 1 degree.
Logged
Chaoticone
5,624
Precision Chaos
Re: Need Help
Reply #6 on:
November 07, 2007, 10:06:18 PM »
In config, toolpath, A-axis rotation enable and use diam. for feedrate should be checked. If they are allready, look at your steps per in motor tuning, divide it by 360.
Hope this helps,
Logged
If you could see the things I have in my head, you would be laughing too.
Print
Pages:
1
Go Up
« previous
next »
