Hello Guest it is March 29, 2024, 01:09:04 AM
Author Topic: Mach3 Windows 10 update -- don't do it  (Read 67994 times)
Re: Mach3 Windows 10 update -- don't do it
« Reply #40 on: June 30, 2018, 12:59:05 AM »
at the current time there are about six manufacturers of external motion controllers that work with Mach4, that is to say thaey have a plugin that
is compatible with Mach4 and their board. Most of thise boards also have a plugin for Mach3  as well. If you are lucky enough to have one of
those boards then 'yes the same controller will work with either Mach3 OR mMach4'. If you have a yet different
controller then 'no, your Mach3 controller cannot be used with Mach4'
« Reply #41 on: June 30, 2018, 08:42:55 PM »
Bryannab mention a patch .062 to be find in macsuppot.com as a new installer. I can not find it. Where is this new installer? I have been affected by the last update of window 10.
  •  9,196 9,196
« Reply #42 on: July 01, 2018, 01:20:51 AM »
http://www.machsupport.com/software/downloads-updates/
« Reply #43 on: July 01, 2018, 04:23:38 AM »
In that section ,I don't see a new installer .062 ?
  •  9,196 9,196
« Reply #44 on: July 01, 2018, 06:43:33 AM »
Just to confuse you (& me) the Mach3 installer has been called R3.043 (it is a modified version of the original R3.043.062)
Install this version of Mach3 over the top of your existing installation.
« Reply #45 on: July 01, 2018, 11:51:48 AM »
Thank you Tweakie. I'll try that.
« Reply #46 on: July 24, 2018, 11:49:41 AM »
Even my Windows 7 computers, none ever are allowed to update.  I feel sorry for you folks who switched to Windows 10. I have Nortons for virus control updating and that's it.
Retired Master Electrician, Commercial HVAC/R Service and lots of Hobbys.
« Reply #47 on: July 24, 2018, 01:58:30 PM »
Don't, as we're far better off than those stuck in the past.  ;D
And using Norton is far worse than anything in Windows.
« Reply #48 on: August 16, 2018, 08:34:47 AM »
You tell them, Ger21. We're not stuck in the past, we're just stuck trying to get our stuff to work. That's all. lol
These are the safest pre workouts for men to try out.
« Reply #49 on: September 05, 2018, 09:34:53 AM »
 With this new Mach3 patch, R3.043,  does anyone know if M10 and M11 still work ?
 I’m trying to use M10 and M11 To control my laser power and it does not seem to be working.
I am using a CNC4PC 62  BOB board  and cannot get a output   Signal from Port 1  pin 15 or Port 2 pin 11 on the Rj45-8  output.
 Chuck
