Hello Guest it is April 18, 2024, 01:07:20 PM
Author Topic: please help  (Read 3510 times)
please help
« on: April 24, 2018, 03:18:38 AM »
unknown G code used
G0 G90 G54 G17 G40 G49 G80
T1 M6
S2500 M3
G0 X3.0 Y0.0
G43 H1 Z.5
G94
G1 Z0.0 F10.0
G3 X1.0 Y2.0 I-2.0 J0.0 F10.0
G0 Z.5
G0 G53 Z0.0
M30
where i have problem?
  •  9,198 9,198
Re: please help
« Reply #1 on: April 24, 2018, 04:27:33 AM »
Try this;
G90.1
T1 M6
S2500 M3
G0 X3.0 Y0.0
G43 H1 Z.5
G94
G1 Z0.0 F10.0
G0 Z.5
G0 G53 Z0.0
M30
Re: please help
« Reply #2 on: April 24, 2018, 05:03:10 AM »
G90.1
T1 M6
S2500 M3
G0 X3.0 Y0.0
G43 H1 Z.5
G94
G1 Z0.0 F10.0
G0 Z.5
G0 G53 Z0.0
M30
i deleted G90 and it work, but problem now on
G0 X3.0 Y0.0
 next unknown G code used
  •  9,198 9,198
Re: please help
« Reply #3 on: April 24, 2018, 05:18:30 AM »
Your Gcode runs just fine here so I am out of suggestions, sorry.  :'(
Re: please help
« Reply #4 on: May 14, 2023, 06:25:57 PM »
I know this is a real old post.  But I had the same problem and was searching for a solution and found this post.
I finally figured out what my problem was. So I thought I'd post my solution here.
I assumed the only real difference between Mach4Lathe and Mach4Mill was screensets used.  That doesn't appear to be the case. I had copied a customized Mach4Lathe profile for a mill profile then changed the screenset to wx4.set.  My new mill profile wouldn't recognize code G90.
However when I started from scratch and copied Mach4Mill for my new mill profile. It would now recognize G90 just fine.
