Hello Guest it is April 25, 2024, 08:50:57 AM
Author Topic: trigonometry center  (Read 2464 times)
trigonometry center
« on: April 23, 2018, 06:12:22 AM »
good morning
I downloaded from the site http://www.tweakie.byethost10.com/17.htm
the following script, I have a problem: do not respect me corner, use mm maybe it's the problem? is it possible to modify it?
THANK YOU
Button A script;
  Call SetUserLed(1102,1) 'open Klaus's video window
  Call SetOemDRO(118,0) 'reset system rotate DRO
  Code "(Locate Datum then click Button B)" 'message for status bar
  Call SetOemDRO(3,1) 'set slow jog rate to 1%
Button B script;
  DoOEMButton (1008) 'zero X axis DRO
  DoOEMButton (1009) 'zero Y axis DRO
  Code "(Locate Reference then click Button C)" 'message for status bar
Button C script;
  Sub Main()
  Call SetUserLed(1103,1) 'close Klaus's video window
  X1pos = GetOemDRO(800) 'read x axis DRO
  Y1pos = GetOemDRO(801) 'read y axis DRO
  If (Y1pos=0) Then GoTo Label1 'avoid divide by zero error
  b = Atn(X1pos/Y1pos)*(180/(4*Atn(1))) 'calculate angle
  b = b - (b*2) 'change sign (+/-)
  Code "G0 X0 Y0" 'move to datum
  While IsMoving () 'wait for task to be completed
  Wend
  Xmove = 70.850 'enter your camera offset here
  Ymove = 1.070 'enter your camera offset here
  Code "G91 G0 X" &Xmove & "Y" &Ymove 'make incremental move
  While IsMoving () 'wait while that happens
  Wend
  Code "G90" 'go back to absolute moves
  Call SetOemDRO(118,b) 'set system rotate DRO
  Label1:
  Call SetOemDRO(3,80) 'reset jog rate to 80%
  Code "(Process complete)" 'message for status bar
  End Sub
« Last Edit: February 13, 2020, 06:23:56 AM by Tweakie.CNC »
  •  9,199 9,199
Re: trigonometry center
« Reply #1 on: April 23, 2018, 07:10:28 AM »
This thread relates to the Local System Rotate and how I used it;  http://www.machsupport.com/forum/index.php/topic,22932.msg160769.html#msg160769
« Reply #2 on: April 23, 2018, 09:35:48 AM »
good morning
thanks Tweakie.CNC for the help. I managed to make it work the problem was mine
I wanted to ask you at the end of the macro inverts the axis (X = y Y = x) and you can modify it? for what I need in the gcode I had to change X with Y, and Y with X. I hope I explained myself.
regards
Offline TPS
  •  2,505 2,505
« Reply #3 on: April 23, 2018, 09:50:02 AM »
the macro does not swap axis, it is Rotation the X/Y plane,
so if you do a jog in X (on Keyboard) then will both axis move-
anyway the macros's are not for trigonometry Center probe, they are for probing a twisted part.
