Hello Guest it is March 28, 2024, 03:20:59 PM
Author Topic: XHC-MK6-ET Ethernet Motion Card with MPG using LPT port  (Read 4319 times)
« on: April 23, 2018, 04:23:28 AM »
Hello everyone.
I am building a 5 axes wood milling CNC. First, I used China LPT Break-out Board, and I made an MPG using LPT port too. They worked correctly at the same time, but there was some noise. So I swap it for MK6-ET card, but my MPG not work.
My computer has an LPT card on-board and an PCIexpress to LPT card.
I just wonder that whether or not I can use Ethernet port and any LPT port at the same time with this card?
Anyone can help me?
https://uphinhnhanh.com/image/zGHzte
  •  9,196 9,196
Re: XHC-MK6-ET Ethernet Motion Card with MPG using LPT port
« Reply #1 on: April 23, 2018, 05:11:07 AM »
Unfortunately you cannot use Ethernet and LPT Port at the same time.
Offline TPS
  •  2,501 2,501
« Reply #2 on: April 23, 2018, 05:20:25 AM »
maybe you can use two spare Inputs on the Controller for MPG A/B and do the selection
via Screen Buttons ?
« Reply #3 on: April 23, 2018, 07:29:23 AM »
Thanks for your reply. Could you explain more clearly the reason why they do not come together, because of Mach3 or computer? This is the first time I use Ethernet card.
« Reply #4 on: April 23, 2018, 07:31:40 AM »
That is a backup idea if there is no way.  Thank you.
  •  9,196 9,196
« Reply #5 on: April 23, 2018, 08:10:46 AM »
Mach3 will not support both LPT and Ethernet options operating at the same time.
« Reply #6 on: April 23, 2018, 10:09:09 AM »
Thanks for your help. Have a good day, Sir.
