Hello Guest it is April 26, 2024, 11:15:01 PM
Author Topic: Spindle as axis doesn't run smooth.  (Read 3776 times)
« on: April 21, 2018, 12:07:52 PM »
I have a GSK Servo Spindle.  Inside the Spindle Drive, I can run it via Step and Direction or 0-10V.
I have it set up to run 0-10V great.
I have to switch it to position mode and then it will read the step and direction from Mach4.  It is not smooth though.  It is very jerky.  Even when I make it an Axis and Jog it, it is jerky.
Now the kicker, I test the motion inside the HiCON Plugin Configuration.  Motion is smooth.  I have steps, velocity, and acceleration set exactly the same in Mach4 config.
So, I'm wondering what is different when I run stuff in Mach vs just the plugin confg screen.
Chad Byrd
Re: Spindle as axis doesn't run smooth.
« Reply #1 on: April 21, 2018, 01:30:39 PM »
hmm.... most likely the accel and vel are still not correct in mach config.
« Reply #2 on: April 21, 2018, 01:33:17 PM »
Do the Plugin Config Screen and Mach interpret the pulse train differently?
Chad Byrd
