Hello Guest it is April 24, 2024, 08:47:32 AM
Author Topic: Probe Signal active error after 2 successful probes  (Read 1308 times)
« on: April 20, 2018, 05:03:09 AM »
Additional to my probing interrupted error I have another strange isse.
I can run my Macro twice with just that "probing interrupted" error. At the third execution I get an additional error saying "Probing signal active!  Cannot continue."
Unfortunately this error message is not issued somwhere internal MACH4 and my macro doesn't get any feedback on that error and I cannot act appropriately.
As in the other Post - here is the log the macro generates (the mentioned error message is on line 92):
Code: [Select]
M1005 debug: initial check on probe contact: 0
M1005 debug: calculated StartHeight (-39) and StopHeight (-70)
M1005 debug: do the first probing with higher speed
G-Code:
G00 G80 G40 G49 G90
G00 G53 Z0.0
G00 G53 X307.0000 Y490.0000
G00 G53 Z-39.0000
G91 G31 Z-70.0000 F500.
Probing interrupted
M1005 debug: verify probe contact after quick approach: 1
M1005 debug: retract spinde
G-Code:
 G91 G00 Z1.0000
M1005 debug: slow tool probe
G-Code:
 G91 G31 Z-1.5000 F20.
M1005 debug: verify probe contact after slow approach: 1
M1005 debug: move spinde all the way up: G90 G00 G53 Z0.0
M1005 debug: Probed Z-Value: -107.4575 and calculated ZOffset: 0.1425
Auto tool setting complete, Offset = 0.1425
G-Code:
G00 G80 G40 G49 G90
G00 G53 Z0.0
G00 G53 Z-39.0000
Probing interrupted
G-Code:
 G91 G00 Z1.0000
G-Code:
M1005 debug: Probed Z-Value: -107.6175 and calculated ZOffset: 0.017500000000013
Auto tool setting complete, Offset = 0.0175
G-Code:
G00 G80 G40 G49 G90
G00 G53 Z0.0
G00 G53 Z-39.0000
Probing interrupted
G-Code:
 G91 G00 Z1.0000
G-Code:
M1005 debug: Probed Z-Value: -108.75 and calculated ZOffset: 1.15
Auto tool setting complete, Offset = 1.1500
As I am not changing anything between the execution of the macro I really don't understand where this error comes from.
Any idea is highly appreciated!
Re: Probe Signal active error after 2 successful probes
« Reply #1 on: April 20, 2018, 10:14:06 PM »
Sounds like a bouncy switch or a little EMI (noise).
