Hello
Guest
it is
April 19, 2024, 07:03:31 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Mach Discussion
General Mach Discussion
mach 3 not working?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: mach 3 not working? (Read 2981 times)
joeaverage
7,575
Re: mach 3 not working?
Reply #10 on:
April 20, 2018, 07:07:27 PM »
sorry misinterpreted the size, should be 6 inches by 8 inches.
Tweakie.CNC
9,198
Super Kitty
Re: G-20,G21 issues
Reply #11 on:
April 21, 2018, 03:36:20 AM »
Hi Wirez1976,
The code snippet you posted was created in Imperial (Inch) units so needs to contain G20 (which it does).
If your machine is not cutting the part the correct size then you should re-calibrate the axes. On the Settings screen click Set Steps per Unit button and follow the on-screen instructions. (Just one point that has confused some - if you tell the machine to move 25.4 it should move 25.4 not 1
rcaffin
1,054
Reply #12 on:
April 21, 2018, 05:53:43 AM »
May have to check the calibration of all the axes too.
If you are at 0,0,0 and you put g0 x10 in, how far does it go?
Roger
joeaverage
7,575
Reply #13 on:
April 21, 2018, 06:51:18 AM »
Hi Eric,
I'm coming to the conclusion that Roger is right....that somehow your profile has been corrupted and your 'steps per unit' is out of whack.
Just double check that Machs native units have not changed...that is Config/Select Native Units
Print
Pages:
1
2
Go Up
« previous
next »
