Hello Guest it is April 25, 2024, 07:24:38 AM
Author Topic: Combine wizard screen into main screen??  (Read 4178 times)
Offline Davek0974
  •  2,606 2,606
« on: April 15, 2018, 08:17:51 AM »
Is there a way to import a wizard screen set into a main screen set??
Both open normally in Machscreen - i have tried making a new page but its shows as a transparent page with images of page 0 on it??
Never tried anything more adventurous that sticking a DRO on a screen before !
Possible or not??
Re: Combine wizard screen into main screen??
« Reply #1 on: April 15, 2018, 09:28:16 AM »
Not sure if ScreenTweek can do that or not? (probably not). Haven't used it in about 10 years.
Best thing is copy all of the images from the wizard folder into the main screen folder, then add a new page to the screen, and re-create the wizard.
Depending on your editor of choice, how you go about it may use different methods.
Offline TPS
  •  2,505 2,505
« Reply #2 on: April 15, 2018, 10:44:04 AM »
if you create a new Screen there will be allways the controls from page 0, thats waht page 0 is used for, to have the possibility
to have controlls witch are shown on all Screens.
to copy a wirzard to a Screen, or the other way around is no Problem.
use Machscreen, open the wizard Screen , select all you want, copy,
open your screenset, goto page you whant to use, paste, finished.
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: April 15, 2018, 11:41:35 AM »
Thanks TPS - i never knew that but it now makes sense.
In that case i cannot do what i want as the original set makes heavy use of screen 0
