So I start Mach4, go to Keyboard setup, setup X jogging, enable keyboard jogging, it works, machine jogs with keyboard. Quit Mach4, restart, Function in Keyboard plugin setup is empty now, and, of course, keyboard jogging doesn't work.
Where do you see the correct data in the profile? The key, 37 in my screen shot, is there, but the Function (green arrow) should have something other than zero, shouldn't it?
There's something about this I don't understand. Do I need to setup keys somewhere else, somewhere other than the keyboard plugin? Do I need to FORCE save the profile somehow? What IS it?
The reason I suspect file attributes or something is I have 4 axes setup to jog and those keys show in the plugin setup, but with NO function. If I add keys, for example, rapid jog with shifted keys, it works 'til I quit Mach and THOSE don't show up AT ALL on next Mach restart in the plugin setup, nor in the machine.in.
Again........keyboard jogging works fine in a given Mach4 session, but quitting Mach4 and restarting, settings are gone and jogging doesn't work, set keys up again, they work until quitting Mach4. All thru this, button jogging and pendant jogging works fine always.
