Hello Guest it is April 16, 2024, 03:10:51 PM
Author Topic: help with analog voltage inputs  (Read 3343 times)
« on: April 08, 2018, 11:46:03 AM »
Having trouble getting the correct voltage values in Mach4 from a Pokeys57E.
I measure voltage at the analog input pins up to 3 volts max but Mach4 registers only see about .8 volts
Does anyone have an idea what is going wrong.  Tech support has not responded with anything helpful yet.
Thanks so much.   Up against a deadline so getting panicked....
Keith
Re: help with analog voltage inputs
« Reply #1 on: April 08, 2018, 01:40:49 PM »
Reply from Polabs this is correct.  Register is fraction of total value. So 1=3.3 volts
« Reply #2 on: May 22, 2020, 05:06:03 PM »
in this video i've used the analog inputs :-) https://www.youtube.com/watch?v=U1z1RcfykGA&t=28s
