Hello Guest it is April 25, 2024, 11:48:29 PM
Author Topic: Super Simple Screen Set  (Read 6015 times)
  •  9,199 9,199
« on: April 05, 2018, 05:18:32 AM »
Here is an excellent Super Simple Screen Set created, for educational purposes, by Graham Waterworth.
The Mach3 Super Simple Screen Set: http://www.machsupport.com/forum/index.php?action=dlattach;topic=35288.0;attach=48518
The Mach4 Super Simple Screen Set:  http://www.machsupport.com/forum/index.php?action=dlattach;topic=35438.0;attach=46697
Update:-
check out the new Lathe Screen sets :- https://www.machsupport.com/forum/index.php?topic=41385.msg271329#msg271329
« Last Edit: July 24, 2019, 08:02:53 PM by Graham Waterworth »
Re: Super Simple Screen Set
« Reply #1 on: September 13, 2018, 09:20:25 AM »
Does it work with a Ethernet ESS controller and Mach3?
Retired Master Electrician, Commercial HVAC/R Service and lots of Hobbys.
« Reply #2 on: September 13, 2018, 11:50:46 AM »
The screenset has nothing to do with the motion controller, so any screen will work with Mach3 with any controller. Where you run into problems is if the screen uses custom macros. Most chinese controllers, and some others, do not run macros properly, as they don't support all Mach3 functions properly. This is typically an issue with probing and auto zero macros.
« Reply #3 on: September 13, 2018, 01:03:33 PM »
Thanks Gerry I have the one I purchased from you  but this may be a  little easier to see the screen in the shop not wearing my readers!   I wish yours had colors for the buttons, Red for Stop and etc.
« Reply #4 on: September 13, 2018, 05:21:13 PM »
Downloaded the .zip file, copied to Mach3 main folder,  unzip start M3. View install Screenset and only parts of the new screen show up??  It works as I can Reset (just guessing at buttons no text)  jog and so on.  What am I doing wrong??
« Reply #5 on: September 13, 2018, 09:06:31 PM »
OK got it loaded and working.  But the Homing does not work right and some of the pull down windows like Motor Tuning do not work.  So it came from a school... oh well it look nicd on to something else.
  •  9,199 9,199
« Reply #6 on: September 18, 2018, 04:14:27 AM »
Problem resolved. This thread refers; http://www.machsupport.com/forum/index.php/topic,38340.msg260054.html#msg260054
