Hello Guest it is April 24, 2024, 09:59:30 PM
Author Topic: Lathe tool offsets, tool table, surfeit of splash screens  (Read 3402 times)
Re: Lathe tool offsets, tool table, surfeit of splash screens
« Reply #10 on: April 07, 2018, 08:54:23 AM »
I also find that typing "T<n>" as a code, either in the program or MDI, does not seem to change the tool number.
use     T0101    for toll #1 in the MDI
« Reply #11 on: April 07, 2018, 09:02:06 AM »
When I start my Mach3 Turn,
I randomly get one of 3 different splash screens
That is what you originaly posted.
Then you reply
I have only one screen set, it's not that which is different between launches.
Me confused ...........
« Reply #12 on: April 08, 2018, 04:28:41 AM »
Pics of screens
« Reply #13 on: April 08, 2018, 04:31:40 AM »
Aha!  Just checking all 3 of these are in the "Bitmaps" folder (not surprisingly), so for some reason the system must make a random choice of which one to display.  Not a bug but a "feature"?
« Reply #14 on: April 08, 2018, 05:26:42 AM »
And some more progress.  I have made the config changes suggested by TPS and checked that my M6start macro contains the correct instructions.  The M30 and Rewind issues are fixed, and I find that if I put a "T010x" instruction in the g code it does select the right tool offset though the tool number doesn't change.  I guess there may be a format issue with the tool no. DRO display box? - will check that.
« Reply #15 on: April 08, 2018, 08:46:25 AM »
The rotating "splash" screens are a normal part of Mach.
Mike
« Reply #16 on: April 08, 2018, 12:08:57 PM »
Thanks Mike!  A feature then.
« Reply #17 on: April 08, 2018, 08:51:01 PM »
Where did the splash screen set come from?
« Reply #18 on: April 09, 2018, 04:14:34 AM »
Rich, as I said, the splash screens are in Mach3/Bitmaps.  It is not a "screen set" in the Mach sense, but a set (i.e. collection) of screens...
