Hello Guest it is March 29, 2024, 02:49:45 AM
Author Topic: centerpiece full (change)  (Read 4721 times)
« on: April 04, 2018, 02:16:16 PM »
406/5000
good evening
I have this macro (not my found on the internet) "centerpiece full" and 'can modify it? I try to explain myself:
1 position me in the middle (approximate)
2 launch the macro, go x +
3 comes down and comes back to touch
4 gets up
and 'here' that I would like to change it, before it rises I would like it to come back a few mm, and if it could double-fingered.
thanks for any help
Rem VBScript To center probe outside diameter Metric Version
Speak (" psizionarsi CINQUE millimetri sopra il pezzo") 'Avviso Vocale
response = MsgBox ("   5 mm    SOPRA IL PEZZO")
Sleep (1000) ' pausa di 1 secondi
Speak (" CONFERMARE centro pezzo pieno") 'Avviso Vocale
Message "INIZIO CENTRO PEZZO PIENO"
response = MsgBox ("CONFERMARE CENTRO PEZZO PIENO")
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
CurrentToolDiameter = GetOemDRO(43) 'gets the current tool diameter
If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
    Call ProbeGrounded()
    Exit Sub
Else
    XCurrent = GetDro(0)
    YCurrent = GetDro(1)
    OutsideDiameter = GetUserDRO(1152)
    Code "G4 P1" 'Pause 1 second to give time to position probe plate
    While IsMoving ()
    Wend
    Call SetDro (0,0.000)
    While IsMoving ()
    Wend
    Call SetDro (1,0.000)
    Code "F50" 'slow feed rate to 100mm/sec
    Code "G90 G0 X" &XNew + OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe Left
    XNew = Xcurrent - OutsideDiameter * .6
    Code "G31 X" &XNew
    While IsMoving() 'wait for the move to finish
    Wend
    XPos1 = GetVar(2000) 'get the probe touch location
    Code "G91 G0 Z10"
    Code "G90 G0 X" &XCurrent 'rapid move back to start point
    Code "G91 G0 X" &XCurrent - OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe Right
    XNew = XCurrent + 75 'probe 75mm to right
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    XPos2 = GetVar(2000)
    Code "G91 G0 Z10"
    XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
    Code "G90 G0 X" &XCenter 'rapid move to the x center location
    While IsMoving ()
    Wend
    Code "G4 P0.25"
    Code "G90 G0 Y" &YNew - OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe up
    YNew = YCurrent + 75
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    YPos1 = GetVar(2001)
    Code "G91 G0 Z10"
    Code "G90 G0 Y" &YCurrent
    Code "G91 G0 Y" &YCurrent + OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe down
    YNew = YCurrent - 75
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    YPos2 = GetVar(2001)
    Code "G91 G0 Z10"
    YCenter = (YPos1 + YPos2) / 2
Rem move To the center
    Code "G90 G0 Y" &YCenter
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Call SetUserDro (1152,YPos2 - YPos1 - CurrentToolDiameter)
    Code "G4 P0.25"
    Code "F" &CurrentFeed 'restore starting feed rate
   Call ReturnG90G91State()
   Exit Sub
End If
Sub ProbeGrounded()
   Code "(Probe plate is grounded, check connection and try again)"
End Sub
Sub ReturnG90G91State()
   If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
      Code "G91"
   End If
   If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
      Code "G0"
   End If
End Sub
Offline TPS
  •  2,501 2,501
Re: centerpiece full (change)
« Reply #1 on: April 05, 2018, 01:40:44 AM »
    Exit Sub
Else
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Code "G91 G0 Z-10"
Rem Probe Left
    Code "G31 X" &XNew
    Wend
    Code "G91 G0 X2"
    Code "G91 G0 Z10"
    Code "G91 G0 Z-10"
Rem Probe Right
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    Code "G91 G0 X-2"
    Code "G91 G0 Z10"
    While IsMoving ()
    Wend
    Code "G4 P0.25"
    Code "G91 G0 Z-10"
Rem Probe up
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    Code "G91 G0 Y-2"
    Code "G91 G0 Z10"
    Code "G91 G0 Z-10"
Rem Probe down
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    Code "G91 G0 Y2"
    Code "G91 G0 Z10"
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Code "G4 P0.25"
   Exit Sub
End If
Sub ProbeGrounded()
End Sub
      Code "G91"
   End If
      Code "G0"
   End If
End Sub
Offline TPS
  •  2,501 2,501
« Reply #2 on: April 05, 2018, 01:43:43 AM »
    Exit Sub
Else
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Code "G91 G0 Z-10"
anyhow this XNew is set nowhere before it is used.
« Reply #3 on: April 05, 2018, 03:24:07 AM »
the macro is OK !! thanks TPS for the help ;)
« Reply #4 on: April 06, 2018, 02:59:33 AM »
good morning
the macro works, but it gives me a problem, at the end of the probing in the dro it displays the dimension of the piece + meta 'probe, I explain if the diameter of the piece is 80 mm
the probe is 6mm in the dro display 83mm, is it possible to correct?
Offline TPS
  •  2,501 2,501
« Reply #5 on: April 06, 2018, 03:20:29 AM »
try to Change this:
CurrentToolDiameter = GetOemDRO(43) 'gets the current tool Diameter
to:
CurrentToolDiameter = GetOemDRO(22) 'gets the current tool diameter
« Reply #6 on: April 06, 2018, 10:21:53 AM »
tried to change always remains the problem, if in settings / probe diameter imposed 3mm (the tip is 6mm) the result is fine.
to make me understand I have to set the half of the real measure.
Offline TPS
  •  2,501 2,501
« Reply #7 on: April 06, 2018, 10:35:22 AM »
can you please change the following oices of code:
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Code "G4 P0.25"
to
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
msgbox  "YPos2: " &YPos2 & " YPos1: " &YPos1 & "Tooldiamter: " &CurrentToolDiameter
    Code "G4 P0.25"
and Report the displayed values?
Where do you set the probe Diameter ? screenshot ?
« Reply #8 on: April 06, 2018, 11:03:57 AM »
I modified the macro, and the piece got worse and it's 80mm
as you can see in the photo the result in the dro is 70.261
Offline TPS
  •  2,501 2,501
« Reply #9 on: April 06, 2018, 11:10:54 AM »
can you mofify the code:
to:
msgbox  "XPos2: " &XPos2 & " XPos1: " &XPos1 & "Tooldiamter: " &CurrentToolDiameter
