I am collecting 4 analog input voltages with programming in the PLC script. Each sweep of the PLC reads the analog voltage and it displays on a meter.
I would like to turn on recording to collect these values for 5 seconds.
I am thinking of a global variable startrecording = "on" could be set with the down script of a button on the screen. Then the PLC script would be checking for the "on" state of that variable and begin building an array with the voltages for 5 seconds when "on". Then after 5 seconds, the PLC script would change the startrecording to "off".
Now I would have the array ready to write to a file. Is there a problem doing this all in the PLC script? Should I put the file operations in the script of a button on the screen? Can I pick up the array as a global variable from that button or should I create a function to pass the array? Not sure just how to sort through all the possibilities to decide what is the best method. It does not seem like a good idea to potentially slow down the PLC script doing file operations.
Thanks!
