Hello Guest it is April 19, 2024, 10:32:21 PM
Author Topic: MPG problems  (Read 1235 times)
MPG problems
« on: April 04, 2018, 02:08:02 AM »
Good morning,
I have a problem with the handwheel when it is connected with the port 2 of SmoothStepper.
When MPG is active on the mode “Velocity” and a different axis from the one that is active during the movement selection, Mach switches the control on the new axis by moving it. At the same time, the axis that has just been released, continues to move alone towards the direction/speed that has been previously set, even if the encoder doesn’t rotate anymore and the only way to stop the movement is to reselect the axis that is moving when the encoder has stopped, or to press or reset the stop button.
This doesn’t happen during the switching from an axis to the other, when the encoder is in movement.
Re: MPG problems
« Reply #1 on: April 18, 2018, 02:10:48 AM »
UP !!! ::)
