Author Topic: Auto zero with ESS not working correctly  (Read 3781 times)
  • CNC is only limited by our imagination.
  • Global Moderator
    • Tweakie.CNC
Re: Auto zero with ESS not working correctly
« Reply #10 on: April 03, 2018, 01:09:30 AM »
worked first time exactly right
It will not be ‘exactly right’ because there will always be some overrun (Z axis deceleration at the chosen feed-rate) and that line of code is intended to apply the correction but, if you are happy with the results then that’s all that is important.
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Offline joeharney100
  • Active Member
« Reply #11 on: April 03, 2018, 01:49:15 AM »
Thanks for all the help, I'll probably be back onto ye when the sensors for my homing arrive and I get going on setting them up
Offline TPS
  • Active Member
« Reply #12 on: April 03, 2018, 02:04:35 AM »
I removed the line "Code "G0 Z" &ZProbePos"
try to replace it by I  "Code "G1 Z" &ZProbePos"
Looks like you machine is not able to follow G0 Speed.
anything is possible, just try it.
  • Active Member
« Reply #13 on: April 03, 2018, 02:30:03 PM »
I changed G0 to G1 and it worked lovely, I've backed up everything so I don't have to try and figure that out again
