Hello Guest it is April 25, 2024, 01:49:15 PM
Author Topic: Probing - what would i need?  (Read 12515 times)
Offline Davek0974
  •  2,606 2,606
Re: Probing - what would i need?
« Reply #60 on: April 15, 2018, 08:25:10 AM »
Have you padded it with Sleep(100) everywhere - it helps.
I am just about at the edge of a tin of petrol and torching the project now - its been fighting me all the way and i have just about had enough - its like trying to force oil and water to mix.
I enjoy a struggle but only if there is light at the end of the tunnel - this probing saga has killed that light, I just want a machine that does what i want, I have binned my ATC thoughts - I can do without that sort of grief I think, if it cant handle simple probing then an ATC has no chance.
I know its all plugin/Mach related but I just get two steps forward and four backwards.
« Reply #61 on: April 15, 2018, 07:08:36 PM »
If its the wizard doing it,
how would i combine the wizard screen into the main screen as a page?
If using Machscreen, just select everything of the wizard page and copy/paste  the wizard screen page into an empty page of the other screen.
Offline Davek0974
  •  2,606 2,606
« Reply #62 on: April 16, 2018, 02:12:39 AM »
Thanks Rich, I'm going to look at that tonight, its not quite that easy as the main set uses layer 0 a lot so all the pages have some space lost. I will likely have to pick and paste only the critical parts.
But it does seem to be wizard related. A friend has also asked me to check the PC RAM is still all there and has enough.
Offline Davek0974
  •  2,606 2,606
« Reply #63 on: April 16, 2018, 12:26:49 PM »
still working on this ;)
I dont suppose some kind soul would let me know exactly which buttons/controls MUST be on a screen to make it function?
I am building a test page but cant even get jog or MDI to give motion - i have it homing ok though
« Last Edit: April 16, 2018, 12:45:12 PM by Davek0974 »
Offline Davek0974
  •  2,606 2,606
« Reply #64 on: April 16, 2018, 01:24:39 PM »
Ok, got it ;)
Jog on/off button :)
But...
Any reason G53 fails?
If i load a file or MDI it I get "cannot use G53 incremental. Block...."
« Last Edit: April 16, 2018, 01:26:26 PM by Davek0974 »
Offline TPS
  •  2,505 2,505
« Reply #65 on: April 16, 2018, 02:03:25 PM »
you can not use a G53 in G91 (incremental)
G53 is allways a absolute (G90) move
Offline Davek0974
  •  2,606 2,606
« Reply #66 on: April 16, 2018, 02:09:09 PM »
That would likely explain it then thanks :)
IIRC it was stuck in G91 when i tried it
Offline TPS
  •  2,505 2,505
« Reply #67 on: April 16, 2018, 02:15:04 PM »
here something about G53 i found in the forum
