Hello Guest it is April 26, 2024, 10:58:24 PM
Author Topic: wx.widgets  (Read 2238 times)
wx.widgets
« on: March 29, 2018, 07:49:27 AM »
Really having trouble getting started with wx.widgets
I can handle a message box and number from user but am not able to get text input from user at this point.  Figuring out much from the documentation is difficult.
I would like to collect a word from the user like filename, or username etc.  1 is minimum # characters and 3 is max I think.
This does not work.
Code: [Select]
local newname = wx.wxGetTextFromUser("Enter a name","Name Entry Screen",name,1,3)
What have I done wrong?  Has anyone found a good source for learning this stuff...  I sure would like some getting started when you know nothing examples for wx.widgets
Thanks!
Re: wx.widgets
« Reply #1 on: March 29, 2018, 08:09:58 AM »
I haven't found a good source for wx.widgets.  But I am using boxes to get info from the operators.
local MyNum = wx.wxGetNumberFromUser("Message", "Prompt", "Caption", 50, 0, 100) --Default, min, max
local MyText = wx.wxGetTextFromUser("Message", "Caption", "Default Value")
http://www.machsupport.com/forum/index.php/topic,36207.0.html
Check out this thread as well.
« Last Edit: March 29, 2018, 08:19:38 AM by Cbyrdtopper »
Chad Byrd
Re: wx.widgets
« Reply #2 on: March 29, 2018, 09:37:52 AM »
One tool that helps with creating GUI objects for wxWidgets is DialogBlocks.
http://www.anthemion.co.uk/dialogblocks/
Steve Stallings
www.PMDX.com
Re: wx.widgets
« Reply #4 on: March 29, 2018, 11:39:37 AM »
This is a cheat sheet for message boxes.
Code: [Select]
--Get input from user
local MyPass = wx.wxGetPasswordFromUser("Message", "Caption", "Default Value")
local MyChoice = wx.wxGetSingleChoice ("message", "caption", ({"Choice1", "Choice2", "Choice3"})) --, wxWindow *parent=NULL, int x=wxDefaultCoord, int y=wxDefaultCoord, bool centre=true, int width=wxCHOICE_WIDTH, int height=wxCHOICE_HEIGHT, int initialSelection=0)
local dir = wx.wxDirSelector ("Choose a Directory", "C:\\")--Caption, default directory --long style=0, const wxPoint &pos=wxDefaultPosition, wxWindow *parent=NULL)
--wxMessageBox Types
--2 = Yes, No
--4 = Ok
--16 = Ok, Cancel
--18 = Yes, No, Cancel
--wxMessageBox Return Values
--Yes = 2
--OK = 4
--No = 8
--Cancel = 16
--Have user click a button
local Iclicked = wx.wxMessageBox("This is my Message", "This is my Caption",2) --Yes,No
wx.wxMessageBox(tostring(Iclicked)) --Show in another message box what the button click in the previous message box returns
Iclicked = wx.wxMessageBox("This is my Message", "This is my Caption",4) --Ok
Iclicked = wx.wxMessageBox("This is my Message", "This is my Caption",16) --Ok, Cancel
Iclicked = wx.wxMessageBox("This is my Message", "This is my Caption",18) --Yes, No, Cancel
--Another way of using a messagebox Type defined with a wx constant
local yesno = wx.wxMessageBox("This is my Message", "This is my Caption", wx.wxYES_NO)
if (yesno == wx.wxYES) then
elseif (yesno == wx.wxNO) then
end
--http://docs.wxwidgets.org/3.0.1/group__group__funcmacro__dialog.html#ga193c64ed4802e379799cdb42de252647
Re: wx.widgets
« Reply #5 on: March 29, 2018, 12:32:21 PM »
Thanks !
