Hello
Guest
it is
April 26, 2024, 01:31:50 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
G53 G00 G90 Z0 - movement with Build 3485
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: G53 G00 G90 Z0 - movement with Build 3485 (Read 2012 times)
litronics
8
on:
March 25, 2018, 06:05:54 AM »
Just updated to the latest build.
The block "G53 G00 G90 Z0", to my understanding, should move only the Z-axis to the machine coordinate 0 and not move in any other direction. In my case the spindle goes all the way up.
However, since the update this block also moves X- and Y-axis to some coordinate what it shouldn't do.
Does anyone experience the same?
Logged
joeaverage
7,575
Re: G53 G00 G90 Z0 - movement with Build 3485
Reply #1 on:
March 25, 2018, 07:42:41 PM »
I think Mach as it ships has two lines of code, one which includes X and Y axes and the other,like your example,
has code affecting the Z axis only.
If you go to the screen load script you will find it and then you can make the choice as to which code runs
and suits your machine and expectations.
Logged
thosj
532
Reply #2 on:
March 26, 2018, 06:04:25 AM »
I could be mistaken, but I thought the OP was asking about a line of Gcode, not Go To Machine Zero or whatever it's called. If he MDI's his line, or it's in a program, it shouldn't move X/Y, should it?
Logged
Tom
joeaverage
7,575
Reply #3 on:
March 26, 2018, 06:35:12 AM »
if indeed it is just a line of code then no X and Y should not move. That line of code though looks like it came straight from the Go To Zero function.
Logged
thosj
532
Reply #4 on:
March 27, 2018, 04:48:16 PM »
Really the OP's block of code should move Z and only Z no matter where it is. If it's in the Go To Zero function, THAT block of code should only move the Z. If there are other G53 lines or if one G53 line also included X and Y, then more that Z will move.
Hopefully the OP will show up back here and tell us what's happening!!
Tom
Logged
Tom
Print
Pages:
1
Go Up
« previous
next »
