Hello Guest it is March 29, 2024, 12:53:29 AM
Author Topic: SMOOTH STEPPER SAVED FILES  (Read 7777 times)
  •  9,196 9,196
Re: SMOOTH STEPPER SAVED FILES
« Reply #20 on: March 28, 2018, 02:02:37 AM »
Hi Frank,
It may not be quite as simple as editing the .xml file but I may be wrong.
It was a couple of years back when I had a bad .xml - I created the new profile and everything then worked as it should. When comparing the bad .xml and the good .xml they both appeared to be identical. My conclusion was that there may be more in the .xml file that an editor reveals.
