Hello Guest it is April 24, 2024, 01:33:48 PM
Author Topic: 2 scripts 1 button  (Read 5641 times)
Re: 2 scripts 1 button
« Reply #10 on: March 20, 2018, 07:55:00 AM »
I try to explain myself,
1 open the script I select gcode mach3
2 opens the list window (and is empty)
3 close
4 open a file from mach3 gcode charge then I close it
5 reopen the script I select gcode mach3, now in the list I find the file opened previously, only that even if there are other files.
the jobs \ gcode section works well
Offline TPS
  •  2,505 2,505
« Reply #11 on: March 20, 2018, 08:02:11 AM »
---the jobs \ gcode section works well
you mean "GCODE LAVORI" ?
are you sure the files are in C:\mach3\gcode ?
because here it works
« Reply #12 on: March 20, 2018, 08:36:58 AM »
yes "GCODE LAVORI" works well
I attach pictures to explain better, those on the list were opened first with "CARICA GCODE" FROM MACH3
Offline TPS
  •  2,505 2,505
« Reply #13 on: March 20, 2018, 08:51:38 AM »
Looks like i has something to do with your file attributes (see Picture)
can cou cross check with gcode lavori files ?
« Reply #14 on: March 20, 2018, 10:36:27 AM »
I tried to change attributes the problem remains
if you delete the files (c; \ mach3 \ gcode) in the selection screen the file names remain
Offline TPS
  •  2,505 2,505
« Reply #15 on: March 20, 2018, 11:59:04 AM »
create a Folder C:\mach3\test
copy a couple of files there
Change the path in the macro
test again
« Reply #16 on: March 20, 2018, 02:08:51 PM »
after many tests at the end I deleted the folder "gcode", recreated the folder inserted files and everything started to work !!
THANKS FOR YOU'RE HELPED TPS !!
