Hello Guest it is April 25, 2024, 12:27:42 AM
Author Topic: Setting error inputs  (Read 7121 times)
« on: March 17, 2018, 11:46:41 AM »
How do I set that driver error to stop all motors.
I use Mach3 and Pokeys57CNC.
Re: Setting error inputs
« Reply #1 on: March 20, 2018, 11:42:23 AM »
Hi All,
OK, it's now resolved.
I have defined an OEM 1003 (stop) button, now I stop all if I have an error on an engine.
I use Closed Loop  Hybrid Servo Step Driver.
« Reply #2 on: October 03, 2019, 05:24:07 AM »
Hi All,
Greetings Fane.
Sorry for bringing this matter back up after this much time, but I would like to ask how you managed to connect the input OEM trigger#1 to the OEM 1003 button.
Looking forward to your response and thank you in advance.
« Reply #3 on: October 04, 2019, 06:13:28 AM »
Finally I found a solution through the brains
« Reply #4 on: October 06, 2019, 03:20:23 AM »
that's what i did
« Reply #5 on: October 06, 2019, 03:26:02 AM »
b2" border="0
c3" border="0
connect-alarm" border="0
erorr" border="0
<a target='_blank' href='https://imgbb.com/'>free image hosting[/url]
« Last Edit: October 06, 2019, 03:27:51 AM by fane »
« Reply #6 on: October 06, 2019, 07:27:14 AM »
Hello again Fane
Thank you for your response.
After I saw your initial post here, I activated the OEM Trig#1 in both the pokeys plugin and Mach3 but it didn't work.
Then I added in your configuration, a brain script for trig#1 which gave false alarms and finally I set in pokeys #1 for X, #2 for Y, and #3 for Z and I made 3 brains accordingly.
Again thank you a lot for help
« Reply #7 on: February 16, 2020, 07:52:01 AM »
Hello all. I know it is an old post but I can not find a description which enables me to implement it.
Pokeys57CNC plus Pokeys 256 Drivers plus MACH3
I have often a Driver error. Could never find the reason so far.
I want to stop the whole machine if it happens so it does not destroy my work every time.
In pokeys config I can set LED1920-24 as described above. As input setting i put eStop. It would work if I could reverse th Input but I can not find where.
The solution with the OEM Trigger#1 I do not understand. Ho should the brains look like?
Any help how to eStop or Stop the whole machine when a Driver has an error would be highly appreciated.
Best
Roman
« Reply #8 on: February 16, 2020, 08:36:49 AM »
Hello exflueger
I will take some photos asap. But tell me first... do you use the usb or the ethernet connection?
« Reply #9 on: February 16, 2020, 10:04:12 AM »
Hello geonik
Thank you. I use Ethernet
