Hello
Guest
it is
April 26, 2024, 06:00:15 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Double touch when using auto zero. Plate grounded error.
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Double touch when using auto zero. Plate grounded error. (Read 3583 times)
TPS
2,505
Re: Double touch when using auto zero. Plate grounded error.
Reply #10 on:
March 12, 2018, 01:10:02 PM »
maybe this
Code "G91 G0
Y-.100
X1.0"
y movement is to small, to go down with z axis
this code is for right upper Corner?
Last Edit: March 12, 2018, 01:13:18 PM by TPS
Logged
Benjammann
25
Reply #11 on:
March 12, 2018, 01:13:12 PM »
I think it stops before it gets that far, but I'll give it a shot this evening.
Logged
Taig Micro Mill. 1/4-20" lead screw. Powered by 1.25hp router with a 4:1 pulley reduction. Driven by Ethernet SmoothStepper to a Gecko 6540. Nema 23 motors. 3 Axis.
TPS
2,505
Reply #12 on:
March 12, 2018, 01:14:15 PM »
Logged
Benjammann
25
Reply #13 on:
March 12, 2018, 01:25:34 PM »
Yes because my table travel is short so I have to locate in the middle of a part. But whenever I get it working ill take this code and transfer it to the other buttons for other corners.
Logged
Benjammann
25
Reply #14 on:
March 19, 2018, 08:54:37 AM »
Hey, Thanks for all your help. This was the solution!
Code "G90 G0 Z.500" 'retract Z to .500 inch
Code "G91 G0 Y-.100 X1.0"
Code "G90 G0 Z-.200"
Code "F" &CurrentFeed 'Returns to prior feed rate
While IsMoving ()
Wend
End If
Logged
yemil
21
Reply #15 on:
April 17, 2018, 11:13:36 PM »
hi .. i am sort of new on this..
just asking and learning....
i dont know much of these codes ...but i need a script for auto zeroing my mach3
could you post the entire script?
thanks in advance
Logged
Print
Pages:
1
2
Go Up
« previous
next »
