Hello Guest it is April 26, 2024, 12:22:44 AM
Author Topic: Using two uc100, with mach3. gecko540 and mach3 interfaceboard.  (Read 5433 times)
Offline Filou
  •  59 59
Re: Using two uc100, with mach3. gecko540 and mach3 interfaceboard.
« Reply #20 on: April 03, 2018, 04:15:06 PM »
Thank you. That seems to be the misleading point. In the main config page, there are two possible entries for LPT ports; say 1 and 2.
In the ports and pins page, I'm using a port number, say 1, to talk to one BoB connected to the UC300. The missing bit: this "1" is NOT connected to the connector numbered "1" on the UC 300 but on the second.  I agree that there is no "rule" that forces anyone to number "ports" and " associated connectors" in a coherent manner, but one would think ...
Documentation is not coherent, in my modest opinion.
cheers, Philippe
« Reply #21 on: April 03, 2018, 04:29:23 PM »
The port numbers on the UC300 are the numbers you enter in Mach3. If you enter a port number of 1 in Mach3, it will indeed be for port 1 on the UC300.
