Hello Guest it is April 24, 2024, 07:01:08 PM
Author Topic: Z-Axis not responding / moving - Help debugging  (Read 5272 times)
Re: Z-Axis not responding / moving - Help debugging
« Reply #10 on: February 23, 2018, 02:41:45 PM »
I don't understand what you mean. Those pin combinations correspond to the step and direction pins of my breakout board. Motor 0 is the X axis, Motor 1 is the Z axis and Motor 2 is the Y axis. Granted the order is strange - XZY instead of XYZ but this definition has been working OK  for years
Offline TPS
  •  2,505 2,505
« Reply #11 on: February 24, 2018, 01:53:54 AM »
sorry that was unclear,
i meaned ro Tweakie's answer where he assumed Pin 4 and 8.
  •  9,199 9,199
« Reply #12 on: February 24, 2018, 02:03:41 AM »
Sorry guys, my mistake - I was picking up the wrong .xml file at my end.
As John suspects, it could be bad pins on the parallel card or the BoB.
« Reply #13 on: February 25, 2018, 02:08:04 PM »
It turned out to be a bad ribbon cable that attached the port inside the computer to the BOB. Those PIC connections are hard to find. Thanks to Tweakie for support.
  •  9,199 9,199
« Reply #14 on: February 26, 2018, 01:45:35 AM »
Excellent, I am pleased that you have found the problem.
