Hello Guest it is April 26, 2024, 07:15:32 PM
Author Topic: DotG post processor for Mach3 Laser operation.  (Read 4858 times)
  •  9,200 9,200
« on: February 19, 2018, 04:36:55 AM »
This is my DotG post processor for Mach3 laser operation.
Because the M11/M10 commands only operate upon axis movement and because DotG only produces it’s 'dot' output when the X and Y axis are stationary an imaginary B axis has been used to enable correct operation.
Within Mach3 the B axis is enabled and set-up with low step value - the Velocity / Acceleration can then be set to determine the ‘dot’ burn time.
« Last Edit: February 19, 2018, 06:30:33 AM by Tweakie.CNC »
Re: DotG post processor for Mach3 Laser operation.
« Reply #1 on: March 27, 2018, 07:45:04 AM »
I really need to start looking at this again.  never got to the point of using the M11/10 commands.  Thank you for the post
Always learning, it's never ending!
  •  9,200 9,200
« Reply #2 on: April 03, 2018, 06:56:54 AM »
For those that are interested in DotG - I spent some time translating the User Manual and Post Processor Manual form Hungarian into English and these .pdf documents can be downloaded from here: http://dotg.weebly.com/download.html
« Last Edit: April 03, 2018, 06:58:32 AM by Tweakie.CNC »
