Hello
Guest
it is
April 20, 2024, 11:34:49 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
PoKeys
(Moderator:
NeoTO
PoKeys homing limit switch issues
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: PoKeys homing limit switch issues (Read 6787 times)
NeoTO
504
Re: PoKeys homing limit switch issues
Reply #10 on:
March 05, 2018, 03:40:07 PM »
So, you configured 2000 pulses for the Z-axis (or only X?) back-off distance using PoKeys application and the motor doesn't back off from the switch after homing?
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
rookie
9
Reply #11 on:
March 05, 2018, 04:30:02 PM »
i set all axis at 2000 no the motor does not back off
rookie
9
Reply #12 on:
March 14, 2018, 05:52:03 PM »
i still have not been able to get the axis to back off switch
thespindoctor
307
Reply #13 on:
June 22, 2018, 06:33:20 PM »
I am having the same problem No backing off after it hits the limit during homing.
NeoTO
504
Reply #14 on:
July 16, 2018, 12:12:33 AM »
Was the issue solved?
Did you configure the back-off distance using the PoKeys application?
www.poscope.com
thespindoctor
307
Reply #15 on:
July 16, 2018, 09:19:06 AM »
Got it! Two switches are wired but only 1 is mapped.
Print
Pages:
1
2
Go Up
« previous
next »
