Hello
Guest
it is
April 19, 2024, 10:58:43 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
PoKeys homing limit switch issues
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: PoKeys homing limit switch issues (Read 6782 times)
Schrubber
1
on:
February 18, 2018, 05:40:15 PM »
I am about at the end of my rope on getting Mach3 to home properly with PoKeys. I just installed a PoKey 57E interface card. I have all the motions running correctly and the limit switches all working. I have the Limit + and limit - wired in series with the home limit switch being the limit- switch. The switches come in and triggers just fine.
When I try to run to REF ALL HOME in Mach3 it runs to the Z - limit switch and stops and gives me a limit switch triggered error and stops. It will not back off the limit switch.
Is there a configuration I am missing? In Mach3 or pulse engineV2?
Schrubber
Logged
TOTALLYRC
861
Re: PoKeys homing limit switch issues
Reply #1 on:
February 18, 2018, 09:34:33 PM »
Hi Schrubber, Make sure you are homing the Z in the positive direction also know as up.
There is a setting to allow you to auto override the limit switch, otherwise you need to go to the settings tab on the main page or hit Alt-6 to get there. You have the option of manually overriding the limits every time it happens or select the auto override function on the same page.
HTH
Mike
Logged
NeoTO
504
Reply #2 on:
February 19, 2018, 12:06:28 AM »
The Mach3 plugin doesn't support it, but you can go in PoKeys application, open Pulse engine settings and configure the 'back-off' distance after homing. Make sure that you click 'Save configuration' so that the settings are stored in the device. Mach3 plugin will not override this setting.
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
rookie
9
Reply #3 on:
March 02, 2018, 08:11:21 PM »
i am attempting to setup mach3 with poyeys 57cncdb25 trying to set up limit switch back off. and soft limits and slow down. i set up in the application tab with no success what do i set up in the app there is a lot of info duplicated . what is necessary what is not needed
Logged
NeoTO
504
Reply #4 on:
March 03, 2018, 04:32:27 AM »
You do not need to configure anything else in PoKeys application other than the back-off distance, which is not supported by the Mach3 plugin.
You will find the setting somewhere in the middle of the screen under 'Homing' options. Enter the number of pulses you want the motors to back-off from the home switch. Note that this configuration must be done for each axis separately. Once done, click 'Save configuration' button on the right.
Everything else is configured via Mach3 plugin.
Logged
www.poscope.com
rookie
9
Reply #5 on:
March 03, 2018, 11:14:33 AM »
i entered as stated when z axis hits switch it stops i have to reset and move axis manually
Logged
NeoTO
504
Reply #6 on:
March 04, 2018, 12:55:36 AM »
How many pulses did you specify? Did you update the firmware to the latest one available (4.3.14)?
Logged
www.poscope.com
rookie
9
Reply #7 on:
March 05, 2018, 10:38:43 AM »
i updated firmware ,the pulse setting is at 2000 until i can get it to work then i will fine tune settings .It still goes to z switch and stops with open switch signal on motor 3 Note all of setting i put in mach and plugin show up in the pulse engine app.
Logged
NeoTO
504
Reply #8 on:
March 05, 2018, 02:26:00 PM »
How did you configure the limit and home switches in Mach plugin?
Logged
www.poscope.com
rookie
9
Reply #9 on:
March 05, 2018, 02:46:15 PM »
X-p13 L++ 13-- Ac low , shared with limit Y- p 11 L++ 11-- act low ,shared with limit Z-p15 L++ 15-- act low ,Shared with limit A-Slaved to y P 13++ L-- 12 act low, shared with limit
Logged
Print
Pages:
1
2
Go Up
« previous
next »
