Hello Guest it is April 26, 2024, 02:02:03 PM
Author Topic: Switching from Mach3 to Mach4  (Read 6867 times)
« on: February 13, 2018, 10:10:43 AM »
In order to help ease the transition for users switching from Mach3 to Mach4, I have created a worksheet you can use to collect and organize your machine settings. If you're interested in taking a peek or giving it a try, use the link below to view the post on the Mach3 section and download the document:
http://www.machsupport.com/forum/index.php/topic,37090.0.html
Happy CNCing!
-Bryanna
« Last Edit: April 23, 2018, 11:18:00 AM by bryannab »
Newfangled Solutions Helpdesk: http://support.machsupport.com
YouTube Support Channel: https://www.youtube.com/c/MachSupportOfficial
Re: Switching from Mach3 to Mach4
« Reply #1 on: January 09, 2019, 04:32:35 PM »
The spreadsheet remains a good tool to have, but we are also implementing an XML wizard in the upcoming build of Mach4. With it, you can load an XML and access all of your important settings from within Mach4. Note: it will not set up a Mach4 profile for you, you still have to configure a profile using the information gathered in the XML wizard. Check out the video below for an introduction and brief walk-through:
https://youtu.be/YX3YHe-Vy5g
-Bryanna
